[GRASSLIST:323] Re: Fwd: Developing a forest fragmentation index
maning sambale emmanuel.sambale at gmail.com
Wed Mar 22 22:48:23 EST 2006
Thank you for the responses.  Will dig into to the manuals you recommended.
Will post later when I made some progress.  Right now i'm into the
generating the Pf which is simply r.neighbors and r.mapcalc commands .
What is bugging me is generating Pff, which counts from the moving
window the forest pixel pairs in 4 cardinal directions.  (see
attached)
Pff = (# of pixel pairs with both pixel forest) / (# of pixel pairs
with at least one pixel forest)
Cheers,
Maning
PS.  how do I install r.li tarball in grass in cygwin?
On 3/22/06, Kari Salovaara <kari.salovaara at pp1.inet.fi> wrote:
> Martin Wegmann wrote:
> > currently r.li, a full rewrite of r.le, is under development. Indices are
> > currently implemented and hopefully soon r.li will enter cvs.
> > Please see previous announcement
> > http://grass.itc.it/pipermail/grass5/2006-January/020875.html.
> > If you are interested to contribute by providing code/algorithms or do some
> > testing etc. you are welcome.
> > regards, Martin
> Thanks. My mistake that I didn't know about that, reason might be wrong
> name of the list GRASS5.
> I'm using only versions 6.x at the moment and was thinking it relates
> only to versions 5.0. I used whole
> night reading archives. Thanks again.
> I shall check or start testing in few days as the idea and
> implementation looks promising from the first sight.
> See also a later message from Paolo Cavallini, [GRASSLIST:280] r.li
> (landscape indices)
> They have also some interesting articles under www.faunalia.com (few
> even in english ;-) )
> Best regards,
> Kari
> Kari Salovaara
> Hanko, Finland
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |Philippine Biodiversity Web Map                           |
| _)_/LI  |www.geocities.com/esambale/philbiodivmap/philbirds.html   |
