[GRASSLIST:376] Re: GRASS 6.1CVS v.in.ascii problem
    Thomas Adams
    Thomas.Adams at noaa.gov
    Sat Mar 25 07:37:36 EST 2006
David,
When I use the correct syntax:
v.in.ascii input=/home/adams/locations.txt output=locs_new format=point fs="|" columns='x double precision,y double precision,z double precision,id int' x=1 y=2 z=3 cat=0
I get a memory fault with GRASS 6.1CVS; again, with GRASS 6.0.2 I have
no problems.
Regards,
Tom
David Finlayson wrote:
> I recall there have been discussions about this (GUI) issue before. If
> this is still in the latest CVS version, report it as a bug. Mike has
> been working hard on the GUI to fix these things.
> David
> On 3/24/06, Thomas.Adams at noaa.gov <Thomas.Adams at noaa.gov> wrote:
>> David,
>> Yes, you are correct. But, understand that I simply copied and pasted from the GRASS GUI --
>> I did not do any
>> editing. I'll try with the correct syntax tomorrow... actually, I have been through this before.
>> The problem is
>> (really) that using v.in.ascii through the GRASS GUI, still fails for me with GRASS 6.1CVS, but
>> works with GRASS
>> 6.0.2.
>> Thanks again for your help...
>> Tom
>> ----- Original Message -----
>> From: David Finlayson <david.p.finlayson at gmail.com>
>> Date: Friday, March 24, 2006 3:41 pm
>> Subject: Re: GRASS 6.1CVS v.in.ascii problem
>>> This command has two syntax errors in it:
>>> format=point> fs=| 'columns=x double precision,y double precision,z
>>> double> precision,id int' x=1 y=2 z=3 cat=0
>>> it should be:
>>> format=point> fs="|" columns='x double precision,y double
>>> precision,z double
>>> Note the position of the quotes in both the "fs" and the "columns"
>>> options. I don't think you can use a pipe character without quoting it
>>> (I don't know about single or double quotes. Try both) and the columns
>>> argument has the quote in the wrong place altogether.
>>> - David
>>> On 3/24/06, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
>>>> David,
>>>> Very interesting. Here are the facts:
>>>> Using a RedHat Linux system
>>>> Both v.in.ascii and v.proj (from lat-long location to LCC
>>> location) work
>>>> fine with GRASS 6.0.2 built from source.
>>>> Using GRASS 6.1CVS (dated 2006-03-18) built from source v.proj (now)
>>>> works, but did not with the 2006-03-04 CVS build; v.in.ascii does
>>> NOT> work -- I get errors:
>>>> WARNING: Unparsable LatLong value found:
>>>>          -80.04916667|39.56444444|860|49450586
>>>>          -84.82388889|38.705|0|49450588
>>>>          -88.50583333|39.35944444|0|49450598
>>>>          -81.20388889|39.56305556|0|49450600
>>>>          -82.17777778|41.34416667|0|49450616
>>>>          -84.95972222|39.73305556|0|113805417
>>>>          -82.92166667|40.35666667|901|113805418
>>>>          -85.15833333|39.57361111|850|113805424
>>>>          -80.64666667|37.72777778|1600|113805425
>>>> My ascii data file looks like:
>>>> -85.71666667|35.43166667|0|113805426
>>>> -86.38055556|36.89527778|500|113805427
>>>> -81.24583333|37.49416667|3100|113805430
>>>> -83.63833333|40.65805556|997|113805432
>>>> -81.71027778|38.18055556|622|113805434
>>>> -85.04916667|41.36|861.7|49460912
>>>> -85.67944444|40.30833333|880|113805437
>>>> -80.76166667|37.475|2159|113805438
>>>> The GRASS 6.0.2 interface generated v.in.ascii command with
>>> output looks
>>>> like:
>>>> Maximum input row length: 42
>>>> Maximum number of columns: 4
>>>> Minimum number of columns: 4
>>>> column: 1  type: double
>>>> column: 2  type: double
>>>> column: 3  type: double
>>>> column: 4  type: integer
>>>> Building topology ...egistering lines:    1000  2000  3000  4000
>>> 5000> 5030 primitives registered
>>>> Building areas:
>>>> 0 areas built
>>>> 0 isles built
>>>> Attaching islands:
>>>> Attaching centroids:
>>>> Topology was built.
>>>> Number of nodes     :   4468
>>>> Number of primitives:   5030
>>>> Number of points    :   5030
>>>> Number of lines     :   0
>>>> Number of boundaries:   0
>>>> Number of centroids :   0
>>>> Number of areas     :   0
>>>> Number of isles     :   0
>>>> The GRASS 6.1CVS interface generated v.in.ascii command with
>>> output (not
>>>> including the warnings/errors, above) looks like:
>>> format=point> fs=| skip=0 'columns=x double precision,y double
>>> precision,z double
>>>> That is, the comand never appears to complete...
>>>> Tom
>>>>> I've use v.in.ascii on text files almost daily and have not
>>>>> experienced problems like you describe. If you can isolate the
>>>>> problem, the developers would probably be very likely to fix
>>> the bug.
>>>>> This is an important module.
>>>>> As an aside, I use sqlite for my attributes, not Postgres and
>>> that may
>>>>> be the difference between our experiences (though Postgres
>>> seems to be
>>>>> the "preferred" database back end for GRASS)
>>>>> David
>>>>> On 3/16/06, David Finlayson <david.p.finlayson at gmail.com> wrote:
>>>>>> If I understand you correctly, you have a table in Postgres that
>>>>>> happens to contain x, y coordinates in addition to other
>>> attributes> >> but is not a PostGIS layer. You were able to convert
>>> the X,Y points
>>>>>> into a GRASS vector file (points) using v.in.db AND this new
>>> vector> >> file seems to work in the lat long Location.
>>>>>> Now when you try to project the new vector file into a LCC
>>> location it
>>>>>> fails. What is the error you are getting? That seems like it
>>> should> >> work.
>>>>>> As a test, have you tried exporting the postgres table as a
>>> csv file
>>>>>> (at least pointid, x and y) and then load the vector with
>>> v.in.ascii?> >> You will be able to link the ID, X,Y CSV file back
>>> to the original
>>>>>> postgres attribute table using the ID column. Does this simple
>>> vector> >> file project?
>>>>>> David
>>>>>> On 3/16/06, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
>>>>>>> David,
>>>>>>> Maybe you don't understand. The Postgres table is for points
>>> and has the
>>>>>>> lat-long location; using v.in.db one is required to identify
>>> the x,y
>>>>>>> location. The additional attributes are read as well, of
>>> course. I can
>>>>>>> successfully import the Postgres table into GRASS into my lat-
>>> long> >>> location. If I then try to re-project the points into a
>>> LCC projection
>>>>>>> (from the LCC location), the v.proj does not seem to work. Is
>>> this what
>>>>>>> you previously understood I was tying to do or do now?
>>>>>>> Who would know whether or not this can be done?
>>>>>>> Thanks for you r responses…
>>>>>>> Tom
>>>>>>>> Ah, I understand now. I'm afraid I can't help you with this.
>>> I've only
>>>>>>>> used databases to hold attribute information not the
>>> topology also. I
>>>>>>>> haven't tried PostGIS yet.
>>>>>>>> David
>>>>>>>> On 3/15/06, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
>>>>>>>>> List:
>>>>>>>>> I have a Lat-Long location into which I have successfully
>>> imported> >>>>> points from Postgres (a further question about this
>>> further below). What
>>>>>>>>> I want to do is to re-project the points into a Lambert
>>> Conic Conformal
>>>>>>>>> location using v.proj. When I try to do this, it does not
>>> work — it
>>>>>>>>> seems as though GRASS does not know how to do this. I have
>>> been able to
>>>>>>>>> do this successfully with points imported using v.in.ascii.
>>> It seems I
>>>>>>>>> am missing something, either conceptually or procedurally…
>>>>>>>>> The further question about using v.in.db, the 'key'
>>> parameter in the
>>>>>>>>> documentation claims this is a string, which makes since to
>>> me, but when
>>>>>>>>> v.in.db is run, GRASS complains that an integer is needed.
>>> I'm guessing
>>>>>>>>> the integer that's supplied is the column/field number
>>> (beginning with
>>>>>>>>> '1'); if true, this seems to be inconsistent by what the
>>> 'x', 'y', and
>>>>>>>>> 'z' fields require — just a thought.
>>>>>>>>> Tom
>>>>>>>>> Thomas E Adams
>>>>>>>>> National Weather Service
>>>>>>>>> Ohio River Forecast Center
>>>>>>>>> 1901 South State Route 134
>>>>>>>>> Wilmington, OH 45177
>>>>>>>>> EMAIL:  thomas.adams at noaa.gov
>>>>>>>>> VOICE:  937-383-0528
>>>>>>>>> FAX:    937-383-0033
>>>>>>>> David Finlayson
>>>>>>> Thomas E Adams
>>>>>>> VOICE:  937-383-0528
>>>>>>> FAX:    937-383-0033
>>>>>> David Finlayson
>>>>> David Finlayson
>>>> Thomas E Adams
>>>> VOICE:  937-383-0528
>>>> FAX:    937-383-0033
>>> David Finlayson
> David Finlayson
Thomas E Adams
VOICE:	937-383-0528
FAX:	937-383-0033
