[GRASSLIST:377] Re: SRTM coastline sharpening
William Kyngesburye woklist at kyngchaos.com
Sat Mar 25 11:03:18 EST 2006
I don't know what to do about the GSHHS coastlines off the top of my
head, but if you use the version 2 SRTM, that's all taken care of.
It's had all ocean areas identified and flat-filled with 0 elevation,
and many lakes have also been identified and flat-filled with the
lake elevation.  No more noise in the water areas.  There are also
polygon shapefiles of the mask used to do this.
On Mar 25, 2006, at 1:09 AM, Luigi Ponti wrote:
> Dear list,
> Following the GRASSNews_vol3 article on SRTM import, I was trying
> to sharpen coastlines using GSHHS shapefiles. However, the imported
> GSHHS vectors are just lines and not areas. Therefore I do not know
> how to generate a raster MASK, because there is no area for
> v.to.rast to produce a filled raster coverage.
> Thanks in advance for any help,
> Luigi
> GRASS6/cygwin user
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
