[GRASSLIST:386] Re: SRTM coastline sharpening
Hamish
hamish_nospam at yahoo.com
Sat Mar 25 23:36:32 EST 2006
> Following the GRASSNews_vol3 article on SRTM import, I was trying to
> sharpen coastlines using GSHHS shapefiles. However, the imported GSHHS
> vectors are just lines and not areas. Therefore I do not know how to
> generate a raster MASK, because there is no area for v.to.rast to
> produce a filled raster coverage.
others have mentioned the new SRTM v2 so I'll leave that, but for the
general vector how-to question:
An area is made up of a boundary and a centroid, so two steps are
needed:
# convert lines to boundaries
v.type line,boundary
# add centroids
v.category op=add # ?!!!
This second part I know possible, but I forget the correct command.
Maybe it is v.build or v.clean?
Hamish
