[GRASSLIST:514] Re: v.extract works from inside QGIS and not inside GRASS
Radim Blazek radim.blazek at gmail.com
Fri Mar 31 09:00:43 EST 2006
Try where='area>400'
Radim
On 3/31/06, Luca Casagrande <luca.casagrande at gmail.com> wrote:
> Hi Radim!
> I was working with v.extract and noticed this (taken from grass prompt..):
> [Starting v.extract from GRASS TOOLS in QGIS]
> option: input=strada at Luca
> option: type=area
> option: layer=1
> option: where=area>400
> option: output=strada_400
> command: v.extract input=strada at Luca type=area layer=1 where=area>400
> output=strada_400 exitCode = 0
> The file was succesfull created and so the tab
> [Quit QGIS]
> GRASS 6.1.cvs (tevere):~ > g.remove vect=strada_400
> REMOVE [strada_400]
> GRASS 6.1.cvs (tevere):~ > v.extract input=strada at Luca type=area layer=1
> where=area>400 output=strada_400 Load cats from the database (table =
> strada, db = /home/geko/lavoro/gis/grass/dati/tevere/Luca/dbf/). DBMI-DBF
> driver error:
> SQL parser error in statement:
> SELECT cat FROM strada WHERE area
> Error in db_open_select_cursor()
> -1 cats loaded from the database
> Writing attributes ...
> The matter if that the same command gives error in GRASS but not in QGIS..
> Thx
> Luca
> "E' molto più bello sapere qualcosa di tutto, che tutto di una cosa (Blaise
> Pascal)."
> GENTOO-GIS Development Team
> jabber: casagrande at jabber.linux.it
