[GRASSLIST:513] v.extract works from inside QGIS and not inside GRASS
Luca Casagrande
luca.casagrande at gmail.com
Fri Mar 31 08:27:56 EST 2006
Hi Radim!
I was working with v.extract and noticed this (taken from grass prompt..):
[Starting v.extract from GRASS TOOLS in QGIS]
option: input=strada at Luca
option: type=area
option: layer=1
option: where=area>400
option: output=strada_400
command: v.extract input=strada at Luca type=area layer=1 where=area>400
output=strada_400 exitCode = 0
The file was succesfull created and so the tab
[Quit QGIS]
GRASS 6.1.cvs (tevere):~ > g.remove vect=strada_400
REMOVE [strada_400]
GRASS 6.1.cvs (tevere):~ > v.extract input=strada at Luca type=area layer=1
where=area>400 output=strada_400 Load cats from the database (table =
strada, db = /home/geko/lavoro/gis/grass/dati/tevere/Luca/dbf/). DBMI-DBF
driver error:
SQL parser error in statement:
SELECT cat FROM strada WHERE area
Error in db_open_select_cursor()
-1 cats loaded from the database
Writing attributes ...
The matter if that the same command gives error in GRASS but not in QGIS..
Thx
Luca
"E' molto più bello sapere qualcosa di tutto, che tutto di una cosa (Blaise
Pascal)."
GENTOO-GIS Development Team
jabber: casagrande at jabber.linux.it
