[GRASSLIST:533] Re: nviz with transparency is horrible slow
Wolfgang
wollez at gmx.net
Fri Mar 31 17:46:38 EST 2006
Hello Glynn,
thanks again for your information! I played this evening with povray,
this is also not a realtime 3d encoder, but offers more possibilities
and with r.out.pvr building topologies is not that hard. I also habe a
3d- viewer for windoofs so that I can see with real time rendering what
I want. But as usual all software has it's disadvantagages and it (the
3d viewer on win) offers no "movie" export.
Wolfgang
Glynn Clements schrieb:
> Wolfgang wrote:
>> I get following output, but when I understand right "direct rendering:
>> No" is the important message.
> No. You won't get direct rendering on Cygwin under any circumstances.
> But that isn't the issue; the issue is whether you get hardware
> accelerated rendering.
> The two are often confused because the stock X.org X11 distribution
> only supports OpenGL acceleration for direct rendering (where the
> rendering is performed by the client), not for indirect rendering
> (where the rendering is performed by the X server).
> Cygwin's X servers don't support direct rendering, but the XWin_GL
> server can do accelerated indirect rendering.
>> OpenGL vendor string: ATI Technologies Inc.
>> OpenGL renderer string: MOBILITY RADEON 9700 x86/SSE2
>> OpenGL version string: 1.2 (1.5.4647 WinXP Release)
> This means that it's using the 3D hardware to perform accelerated
> rendering. In which case, there isn't anything more which you can do
> to improve the situation.
