[GRASSLIST:518] Re: nviz with transparency is horrible slow
Fri Mar 31 10:06:14 EST 2006
Wolfgang wrote:
> is it usual that nviz gets quite slow when transparency is used? (I'm
> running grass 6.1cvs on cygwin)
I would expect translucency to have a speed penalty.
Cygwin provides an "experimental" version of the X server which
includes hardware acceleration for OpenGL. You might see if that
helps.
