[GRASSLIST:519] Re: nviz with transparency is horrible slow
Wolfgang wollez at gmx.net
Fri Mar 31 11:07:01 EST 2006
If I did the installation correctly, this X server doesn't improve the
situation. But the question is also if nviz is programmed to support OpenGL?
Wolfgang
Glynn Clements schrieb:
> Wolfgang wrote:
>> is it usual that nviz gets quite slow when transparency is used? (I'm
>> running grass 6.1cvs on cygwin)
> I would expect translucency to have a speed penalty.
> Cygwin provides an "experimental" version of the X server which
> includes hardware acceleration for OpenGL. You might see if that
> helps.
