[GRASSLIST:516] Re: LRS
Tim Semmelhaack
t.semmelhaack at hamburg-consult.de
Fri Mar 31 09:38:44 EST 2006
Hello,
> 1) The value specifying certain fix point in real world, e.g.
> milepost, milestone. The point has usually a physical representation
> but I mean the value it represents i.e. mile, kilometer,
> not the physical object.
I German we use the expression "Kilometrierung" but I haven't found an
English counterpart.
> 2) The value which specifies the distance along a linear object
> from 1) (from milepost) to a certain position on the linear feature.
> The distance is given for example in meters or feets.
> 3) How to call the module which generates labels of existing LRS
> Here is example of a map with labels and strokes generated
> byt this module: http://mpa.itc.it/radim/lrs/stationing-small.png
In Arcview the labels of linear referencing are called "hatch"
> I hope that native english speakers and people working with LRS can help.
Regards
Tim
