[GRASSLIST:526] Re: GRASS test suite
Sören Gebbert
soerengebbert at gmx.de
Fri Mar 31 14:34:02 EST 2006
On Friday 31 March 2006 14:19, Radim Blazek wrote:
> On 3/31/06, "Sören Gebbert" <soerengebbert at gmx.de> wrote:
> > Hi Radim,
> > many thanks for this info, that sounds very promising!
> > With those tools, the test suite should run. If not, i will make
> > it run!
> > Maybe i only need to rename some progs and stuff (awk -> gawk).
> > And HURRAY, md5sum is present. :)
> > > MSYS includes:
> > > basename.exe env.exe install.exe od.exe tail.exe
> > > bzip2.exe expr.exe install-info.exe patch.exe tar.exe
> > > cat.exe false.exe less.exe ps.exe tee.exe
> > > chmod.exe find.exe ln.exe rmdir.exe texindex.exe
> > > cmp.exe fold.exe ls.exe rm.exe touch.exe
> > > comm.exe gawk.exe m4.exe rxvt.exe tr.exe
> > > cp.exe grep.exe make.exe sed.exe true.exe
> > > cut.exe gzip.exe makeinfo.exe sh.exe uname.exe
> > > date.exe head.exe md5sum.exe sleep.exe uniq.exe
> > > diff3.exe id.exe mkdir.exe sort.exe vim.exe
> > > diff.exe info.exe mount.exe split.exe wc.exe
> > > dirname.exe infokey.exe mv.exe stty.exe xargs.exe
> > > > And how about the existing shell scripts in grass,
> > > > do they work with MSYS and GRASS with windows?
> > > At moment no because of the problem with variables I reported yesterday,
> > > but they will work soon using sh.exe from MSYS.
> > What does soon mean, do you provide a new zip archive?
> > Or can i handle this?
> > Sorry, i have no clue of windows ... or how qgis handles the shell.
> Soon means the next week but you don't need to wait for it
> because the problem applies only to scripts using g.parser.
So i will have a problem. Many scripts of the framework using g.parser.
Some of them are designed as stand alone program (md5 sum check).
Can i handle this by my own or do i have to wait?
Best
Soeren
> Radim
> > Best regards
> > Soeren
> > > Radim
> > Analog-/ISDN-Nutzer sparen mit GMX SmartSurfer bis zu 70%!
> > Kostenlos downloaden: http://www.gmx.net/de/go/smartsurfer
