[GRASSLIST:984] New shiny GRASS test suite
Sören Gebbert soerengebbert at gmx.de
Tue May 2 19:12:15 EDT 2006
Dear users and devs,
a new version of the grass test suite is available.
New features are:
* a new, small test location is available as part of the test suite with vector, raster, raster3d and dbf files
* The test suite checks now the dependences of grass and has a build in function to execute only those scripts
   which meets these dependences (e.g.: if gdal is supported by grass -> r.in.gdal and r.out.gdal tests are available)
   These dependences have to be set in the test scripts (e.g.: NEED_GDAL=yes for gdal dependence)
* 72 test scripts are available, including most of the r3.* , g.* and db.* modules
  and also a lot of r.* and v.*  modules
  More than 250 tests can be performed
* new scripts are added for the correct grass start -> grass starts with the new test location, spearfish is not needed anymore
* The coding style fulfills now parts of the SUBMITTING_SCRIPTS guidline
You can get this test suite here:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/GRASS_Testsuite-0.2.0.2.tar.bz2
The current output with valgrind check:
http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html/
You have to use a recent version of grass6.1-cvs!!! to get the test suite work.
If you want to use the test suite just do the following steps in a bash or tcsh:
cd /tmp
wget http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/GRASS_Testsuite-0.2.0.2.tar.bz2
tar xjvf GRASS_Testsuite-0.2.0.2.tar.bz2
cd GRASS_Testsuite
./StartGRASS.sh
#After doing this you can start the test suite with the following command to
#performe every available test (if you want add the flag -u for the error detection tests)
./RunGRASSTestSuite.sh -dgrv3h
#Now the html output is created in the /tmp directory, just open the file
/tmp/GRASSTestSummary.html
#with any browser to see detailed results of the test
firefox file:///tmp/GRASSTestSummary.html
Thats all :)
Have fun
I hope for some feedback! It would be very interesting if this test suite also
works with MacOS X.
Waiting for your suggestions
Best regards
Soeren
btw.:
A strange thing happens with r.terraflow which produce a assertion and a core dump if
running within valgrind (flag -m). Can anybody approve this? Just call within grass:
./RunGRASSTestSuite.sh -mh module=./Tests/raster/r.terraflow-test.sh
