[GRASSLIST:1005] Re: GLOBE DEM error
Stuart Edwards
sedwards2 at cinci.rr.com
Thu May 4 14:48:47 EDT 2006
The source is NOAA's NGDC website <www.ngdc.noaa.gov/mgg/topo/report/
s11/s11B.html>
The whole system was apparently set up using GRASS, but the support
files provided for GRASS downloads only include cellhd and colr. I
tried adding a 'dummy' hist file but it didn't work -- probably
because I didn't know what to put in the 'history' part and left it
blank.
_______________
On May 3, 2006, at 11:01 PM, Hamish wrote:
>> I'm trying to view a GLOBE DEM panel using 61cvs on OSX 10.4.6 and
>> received the following error message. What does this mean and how
>> can I fix the problem? Thanks for any help.
>> WARNING: can't get history information for [g10s] in mapset [user]
>> while executing
>> "close $rt"
>> (procedure "DmRaster::display" line 27)
>> invoked from within
>> "DmRaster::display $node"
> All raster maps should have a metadata "history" file stored in
> $MAPSET/hist/$MAPNAME
> Apparently yours is missing.
> the warning comes from G_read_history(), which in turn is called by
> these modules:
> imagery/i.maxlik/hist.c
> imagery/i.ortho.photo/photo.rectify/exec.c
> imagery/i.smap/shapiro/history.c
> raster/r.compress/main.c
> raster/r.carve/support.c
> raster/r.info/main.c
> raster/r.le/r.le.patch/trace.c
> raster/r.mapcalc/map.c
> raster/r.null/null.c
> raster/r.random/support.c
> raster/r.resample/main.c
> raster/r.support/front/front.c
> raster/r.support/modhist/modhist.c
> How did you import the data & where did it come from?
> Try re-importing?
> Hamish
