[GRASSLIST:1012] Re: GLOBE DEM error
Fri May 5 07:55:40 EDT 2006
> The source is NOAA's NGDC website <www.ngdc.noaa.gov/mgg/topo/report/
> s11/s11B.html>
> The whole system was apparently set up using GRASS, but the support
> files provided for GRASS downloads only include cellhd and colr.  I
> tried adding a 'dummy' hist file but it didn't work -- probably
> because I didn't know what to put in the 'history' part and left it
> blank.
Make a dummy map, e.g.
r.mapcalc one=1
and then just copy the hist/ file to your needed map name.
I don't think having the wrong info in it will hurt much, you can edit
it if you like.
Hamish
