[GRASSLIST:1016] Re: GLOBE DEM error
Stuart Edwards sedwards2 at cinci.rr.com
Fri May 5 08:51:00 EDT 2006
Thanks.  It seems that just the presence of an empty hist directory
is enough to trigger the creation of the file; subsequent imports
worked fine once it was present.
Stuart
On May 5, 2006, at 7:55 AM, Hamish wrote:
>> The source is NOAA's NGDC website <www.ngdc.noaa.gov/mgg/topo/report/
>> s11/s11B.html>
>> The whole system was apparently set up using GRASS, but the support
>> files provided for GRASS downloads only include cellhd and colr.  I
>> tried adding a 'dummy' hist file but it didn't work -- probably
>> because I didn't know what to put in the 'history' part and left it
>> blank.
> Make a dummy map, e.g.
> r.mapcalc one=1
> and then just copy the hist/ file to your needed map name.
> I don't think having the wrong info in it will hurt much, you can edit
> it if you like.
> Hamish
