[GRASSLIST:1025] Re: problem with compiling grass 5.4 source
    Stefano Costa
    steko at iosa.it
    Sat May  6 06:34:43 EDT 2006
Il giorno sab, 06/05/2006 alle 12.23 +0200, Simone Pittaluga ha scritto:
> Hello,
> I have a problem with configure procedure in grass 5.4 and grass 5.7.
> My system is a Fedora 5 with all sources of grass needed packages.
> When i run ./configure with or without all options set the configure program
> exit with error when execute 'checking system version (for dinamic
> loading)... ../../grass-5.4.0/configure: line 12492: syntax error:
> unexpected end of file.
> I have the same error with tcl/tk 8.3.5 and 8.4.9 but 8.4.13 is ok.
Ciao Simone,
here you can find RPMs for Fedora 5 of the latest stable version of
GRASS (6.0).
http://ftp.gwdg.de/pub/misc/freegis/intevation/freegis/fedora/5/RPMS/
Don't know if it can help you, but you should in general use this
version.
Ciao,
Steko
Stefano Costa
http://www.iosa.it Software Open Source per l'Archeologia
Jabber: steko at jabber.linux.it
GnuPG Key ID 1024D/0xD0D30245
Linux Registered User #385969 counter.li.org
