[GRASSLIST:1027] Re: problem with compiling grass 5.4 source
Simone Pittaluga
pitta at ibidem.it
Sat May 6 09:11:51 EDT 2006
Stefano Costa Scrive:
> Il giorno sab, 06/05/2006 alle 12.23 +0200, Simone Pittaluga ha scritto:
>> Hello,
>> I have a problem with configure procedure in grass 5.4 and grass 5.7.
>> My system is a Fedora 5 with all sources of grass needed packages.
>> When i run ./configure with or without all options set the configure program
>> exit with error when execute 'checking system version (for dinamic
>> loading)... ../../grass-5.4.0/configure: line 12492: syntax error:
>> unexpected end of file.
>> I have the same error with tcl/tk 8.3.5 and 8.4.9 but 8.4.13 is ok.
> Ciao Simone,
> here you can find RPMs for Fedora 5 of the latest stable version of
> GRASS (6.0).
> http://ftp.gwdg.de/pub/misc/freegis/intevation/freegis/fedora/5/RPMS/
> Don't know if it can help you, but you should in general use this
> version.
> Ciao,
> Steko
> Stefano Costa
> http://www.iosa.it Software Open Source per l'Archeologia
> Jabber: steko at jabber.linux.it
> GnuPG Key ID 1024D/0xD0D30245
> Linux Registered User #385969 counter.li.org
thanks for help but i have a lot of data to share with other system that run
grass 5.4.
Ciao
Simone
