[GRASSLIST:1024] Re: problem with compiling grass 5.4 source
Maciek Sieczka
werchowyna at epf.pl
Sat May 6 06:37:23 EDT 2006
On Sat, 06 May 2006 12:23:49 +0200
"Simone Pittaluga" <pitta at ibidem.it> wrote:
> I have a problem with configure procedure in grass 5.4 and grass 5.7.
> My system is a Fedora 5 with all sources of grass needed packages.
> When i run ./configure with or without all options set the configure
> program exit with error when execute 'checking system version (for
> dinamic loading)... ../../grass-5.4.0/configure: line 12492: syntax
> error: unexpected end of file.
Please post your exact ./configure syntax and the error.
> I have the same error with tcl/tk 8.3.5 and 8.4.9 but 8.4.13 is ok.
Use 8.4.13 then?
Note 5.7 is old. Don't use it. 6.x is it's continuation, but much more
developed and bugfixed. Use 6.0.2 at least (or 6.1 CVS preverably, 6.2
coming soon).
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
