[GRASSLIST:1026] Re: problem with compiling grass 5.4 source
Simone Pittaluga
pitta at ibidem.it
Sat May 6 09:08:37 EDT 2006
Maciek Sieczka Scrive:
> On Sat, 06 May 2006 12:23:49 +0200
> "Simone Pittaluga" <pitta at ibidem.it> wrote:
>> I have a problem with configure procedure in grass 5.4 and grass 5.7.
>> My system is a Fedora 5 with all sources of grass needed packages.
>> When i run ./configure with or without all options set the configure
>> program exit with error when execute 'checking system version (for
>> dinamic loading)... ../../grass-5.4.0/configure: line 12492: syntax
>> error: unexpected end of file.
> Please post your exact ./configure syntax and the error.
>> I have the same error with tcl/tk 8.3.5 and 8.4.9 but 8.4.13 is ok.
> Use 8.4.13 then?
> Note 5.7 is old. Don't use it. 6.x is it's continuation, but much more
> developed and bugfixed. Use 6.0.2 at least (or 6.1 CVS preverably, 6.2
> coming soon).
> Maciek
> W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
> http://katalog.panoramainternetu.pl/
I now use tcl/tk 8.4.13 and i compile that without problem. (the problem was
the same of grass)
I have a lot of data to share and other system run grass 5.4 and i need to
use the same version.
Thank's for help
Simone
