[GRASS-user] How to unsubscribe from old mailing list?
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Thu May 11 11:50:20 EDT 2006
Maybe you can clarify some questions...
If I unsuscribe from the baylor GRASSLIST will I be able to see messages
posted to it? I mean, will I lost all the post of the users that are in
late with changing?
What is the procedure you suggest to do? Just unuscribe from old
maillist and subscribe to the new one?
Markus Neteler wrote:
>Dear subscribers,
>sorry, I forgot to explain how you unsubscribe from the
>old GRASSLIST at baylor.edu list:
>To unsubscribe, send email to:
> listproc at baylor.edu
>from the address you used to subscribe to the list.
>In the *body* of the message, write the command:
> unsubscribe GRASSLIST
>Note: Please do not send "unsubscribe" messages to the
>user mailing list - this won't work. You have to use the
>listproc at baylor.edu email address as indicated above.
>Markus
>On Thu, May 11, 2006 at 09:27:21AM -0500, Steven Gordon wrote:
>>Hello,
>>I am subscribed to GRASSLIST at baylor.edu.
>>How do I unsubscribe from that list?
>>Thank you.
>_______________________________________________
>grassuser mailing list
>grassuser at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grassuser
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
