[GRASS-user] How to unsubscribe from old mailing list?
Markus Neteler neteler at itc.it
Thu May 11 12:15:14 EDT 2006
On Thu, May 11, 2006 at 05:50:20PM +0200, Massimiliano Cannata wrote:
> Maybe you can clarify some questions...
> If I unsuscribe from the baylor GRASSLIST will I be able to see messages
> posted to it? I mean, will I lost all the post of the users that are in
> late with changing?
No, because I have subscribed the old list as "user" in the new
list (some years ago). This is how the archive was created.
Nothing should get lost.
> What is the procedure you suggest to do? Just unuscribe from old
> maillist and subscribe to the new one?
Nearly:
- I have already subscribed all users to the new list (you posted
  in this moment to the new list which only subscribers can do)
    -> nothing to do
- you have to unsubscribe yourself from the old list, because I
  don't have permissions to do so.
    -> to do for you
The transition should be really smooth. All emails arrive, and you
were already subscribed to the new list by me. The only thing which
*you* have to do is to unsubscribe from the old list (and use the
new address <grassuser at grass.itc.it> apparently). Mails which are
still sent to the old address will be distributed through the
new list as well so that you will receive also those.
Hope this clarifies it,
 Markus
> Markus Neteler wrote:
> >Dear subscribers,
> >sorry, I forgot to explain how you unsubscribe from the
> >old GRASSLIST at baylor.edu list:
> >To unsubscribe, send email to:
> > listproc at baylor.edu
> >from the address you used to subscribe to the list.
> >In the *body* of the message, write the command:
> > unsubscribe GRASSLIST
> >Note: Please do not send "unsubscribe" messages to the
> >user mailing list - this won't work. You have to use the
> >listproc at baylor.edu email address as indicated above.
> >Markus
> >On Thu, May 11, 2006 at 09:27:21AM -0500, Steven Gordon wrote:
> >>Hello,
> >>I am subscribed to GRASSLIST at baylor.edu.
> >>How do I unsubscribe from that list?
> >>Thank you.
> >_______________________________________________
> >grassuser mailing list
> >http://grass.itc.it/mailman/listinfo/grassuser
> Eng. Massimiliano Cannata
> Scuola Universitaria Professionale della Svizzera Italiana
> Istituto Scienze della Terra
> Via Trevano, c.p. 72
> CH-6952 Canobbio-Lugano
> Tel: +41 (0)58 666 62 14
> Fax +41 (0)58 666 62 09
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
