[GRASS-user] Re: [GRASSLIST:1065] Re: v.clean doesn't create dbf
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Sun May 14 20:37:58 EDT 2006
> Why are you are reporting for layer=1 while you want to use layer=2 in
> v.surf.rst (as I see below)?
> > v.surf.rst input=int2 layer=2 dmax=25.000000 dmin=5.000000
> > elev=dem_int2 zmult=1.0 tension=40. smooth=0.1 segmax=40 npmin=300
I haven't noticed that. In my memory, the "Field value" n v.surf.rst
GUI was related to the column with the values I want to interpolate,
not with the layer....
my fault
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
