[GRASS-user] Re: [GRASSLIST:1065] Re: v.clean doesn't create dbf
Maciek Sieczka
werchowyna at epf.pl
Sun May 14 09:13:35 EDT 2006
On Fri, 12 May 2006 08:33:48 -0300
"Carlos \"Guâno\" Grohmann" <carlos.grohmann at gmail.com> wrote:
> This is the output of v.info:
> v.info map=int2 layer=1
<snip>
> | Map is 3D: 0
<snip>
> v.info map=int2 layer=1 -c
> Displaying column types/names for database connection of layer 1:
> INTEGER|cat
> DOUBLE PRECISION|alt
> INTEGER|alt2
<snip>
Why are you are reporting for layer=1 while you want to use layer=2 in
v.surf.rst (as I see below)?
> v.surf.rst input=int2 layer=2 dmax=25.000000 dmin=5.000000
> elev=dem_int2 zmult=1.0 tension=40. smooth=0.1 segmax=40 npmin=300
<snip>
> Now the most weird.. if I set the zcolumn=1 (cat), it works.
Not weird at all. You have to set zcolumn to something - as these values
will be interpolated. Unless you set "layer=0" in order to use the
vector's Z coordinates (if it's 3D, but your is not).
Maciek
W polskim Internecie są setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
