[GRASS-user] resampling (r.resamp.rst) question
Hamish
hamish_nospam at yahoo.com
Mon May 15 00:46:00 EDT 2006
> I have a problem with r.resamp.rst
> The region is at same resolution
> g.region -p -m
> nsres: 3.139134
> ewres: 3.139134
> When i try to use r.resamp.rst for resampling a dem (to use in nviz)
> of which the resolution is :
> r.info map=dem -s
> nsres=35.38837407
> ewres=35.38837407
> I have the following message :
> Resolution of the layer in entry does not correspond to the resolution
> of the current region!
> What's wrong please ?
Use r.resamp.rst to set the target resolution, not g.region.
g.region res=35.38837407
or
g.region rast=dem
g.region -p
nsres=35.38837407
ewres=35.38837407
r.resamp.rst ew_res=3.139134 ns_res=3.139134
Hamish
