[GRASS-user] nviz: transparency, masks
Martin du Saire mdusaire at umn.edu
Mon May 15 10:31:21 EDT 2006
Okay, I *thought* I  figured it out...
Here's the situation:
[Cygwin\Grass6.0 on XP]
created an r.buffer which I wanted to use to control transparency of
dem displayed with nviz.  I have tried one distance, and multiple
distances.  I have tried r.reclass, but cannot figure out how nviz
uses the class values to determine if and how each buffer zone is displayed.
Is it possible to use a raster buffer to control transparency in nviz?
How does nviz use the class values to control the degree of
transparency of the surface color?
How does it treat the "no data" pixels in the buffer?
Thanks.
M
At 11:35 AM 5/12/2006, you wrote:
>Hi,
>I'm trying to use a raster buffer to control transparency of a soil
>map overlayed on a dem, but can't figure it out based on nviz tutorial.
>Help.
>M
>_______________________________________________
>grassuser mailing list
>grassuser at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grassuser
