[GRASS-user] newbie question
Peter Manousos
Peter.Manousos at noaa.gov
Thu May 18 16:24:08 EDT 2006
Hi..
We have a set of lat/lon contour data we converted into ESRI shape
file(s). I am using GRASS to verify the data has been converted
properly for GIS use by importing/converting the shape file data using
v.in.shape. I am then plotting the resultant vector map using d.vect
Although the contours are successfully plotted - the contour labels are
not.
I do not see in the documentation how plotting of contour labels is
accomplished from a vector map. I thought the vector attributes where
automatically handled if properly stored in the original .dbf file.
What am I missing ?
Pete
