[GRASS-user] newbie question
Dylan Beaudette
dylan.beaudette at gmail.com
Thu May 18 16:48:17 EDT 2006
On Thursday 18 May 2006 13:24, Peter Manousos wrote:
> Hi..
> We have a set of lat/lon contour data we converted into ESRI shape
> file(s). I am using GRASS to verify the data has been converted
> properly for GIS use by importing/converting the shape file data using
> v.in.shape. I am then plotting the resultant vector map using d.vect
> Although the contours are successfully plotted - the contour labels are
> not.
> I do not see in the documentation how plotting of contour labels is
> accomplished from a vector map. I thought the vector attributes where
> automatically handled if properly stored in the original .dbf file.
> What am I missing ?
> Pete
Welcome aboard.
vector attributes will not be displayed by default. you can have them shown by
adding the following flags to d.vect:
d.vect contours disp=shape,attr ...
you will need to specify the column name containing your contour labels. check
the d.vect man page for details.
Cheers,
Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
