[GRASS-user] newbie question
Hamish
hamish_nospam at yahoo.com
Thu May 18 21:13:28 EDT 2006
> We have a set of lat/lon contour data we converted into ESRI shape
> file(s). I am using GRASS to verify the data has been converted
> properly for GIS use by importing/converting the shape file data using
> v.in.shape. I am then plotting the resultant vector map using d.vect
> Although the contours are successfully plotted - the contour labels
> are not.
> I do not see in the documentation how plotting of contour labels is
> accomplished from a vector map. I thought the vector attributes where
> automatically handled if properly stored in the original .dbf file.
> What am I missing ?
You need to use GRASS 6. Vector attributes in GRASS 5 are very limited.
Import is with v.in.ogr, display with (new) d.vect.
good luck,
Hamish
