[GRASS-user] Trento3D screenshots redone
Markus Neteler
neteler at itc.it
Thu May 18 18:17:51 EDT 2006
On Thu, May 18, 2006 at 12:57:56PM -0400, Thomas Adams wrote:
> Markus,
> Very, very nice! Is there a tutorial on how this is done?
That's pretty easy:
- get 2D building polygons with heights as attribute column (v.in.ogr)
- get DEM (r.in.gdal)
- get orthophoto (r.in.gdal)
- interpolate dem to highres (I used 2m pixels) with r.surf.rst
- extrude 2D buildings to 3D (v.extrude, give building heights attribute
column as option and 2m DEM as elevation)
- start nviz with
nviz dem2m vect=buildings3d col=orthophoto
that's it!
> If not, is it
> possible to use the Trento dataset to create one? One possible use ? if
> other details can be worked out ? is to create maps of flood inundation
> to show buildings affected by flooding.
OK, I couldn't resist :-)
http://mpa.itc.it/markus/grass61/demos/rlake/
-> see at bottom for new screenshot with flooding
(needs r.lake which is still not in CVS...)
> I understand one must have the
> building data (how was *that* obtained?).
The Trento municipality was going out and digitizing all builings.
Another option is to digitize building footprints from orthophoto
(v.digit) and assign a typical height to each building.
If you are lucky, get 3D DXF buildings and import them with
the recently updated v.in.dxf.
> This type of presentation is
> very effective in capturing the imagination (as it were) of those
> possibly affected by flooding.
Fully agreed and done. Except for r.lake everything is in
6.1-CVS.
Only the merge of the flood map with orthophoto could be better
(r.mapcalc will kill the color table, r.patch as well). In February
I did a trick in nviz (see earlier flood screenshots) which I
don't remember today (maybe I loaded the DEM twice or so).
Best,
Markus
> Regards,
> Tom
> Markus Neteler wrote:
> >Hi,
> >I have re-done the screenshots of Trento3D (based on
> >2D building footprint polygons, extruded with v.extrude):
> >http://grass.itc.it/grass61/screenshots/index.php
> >Now the correct building heights are used.
> >Still have to add the 3D trees :-)
> >Markus
> >_______________________________________________
> >grassuser mailing list
> >grassuser at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grassuser
> Thomas E Adams
> National Weather Service
> Ohio River Forecast Center
> 1901 South State Route 134
> Wilmington, OH 45177
> EMAIL: thomas.adams at noaa.gov
> VOICE: 937-383-0528
> FAX: 937-383-0033
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
