[GRASS-user] Trento3D screenshots redone
Māris Nartišs
maris.nartiss at gmail.com
Sat May 20 08:24:47 EDT 2006
I have to appologise for delay with r.lake. Not everything is going always as
planed.
I attached r.lake source code (no changes) and simple description file. I'm
not english native speaking person and almost offline (expedition) and have
no dictionary - feel free to correct my text.
If I can help in any way - feel free to contact me.
wbr,
Maris.
On Friday 19 May 2006 21:46, Jeroen Wortel wrote:
> Hi Markus,
> Is the r.lake routine available?
> We are doing some (simple) river inundation analysis as well;
> we create a raster map of our vector river model with value 1,
> multiply this by the desired water (flood) height, add this to our
> DEM and use r.mapcalc to extract all cells lower or equal to the
> flood level. Then we convert this to a vector file, and extract the
> polygon containing the main stream and the connected flooded areas
> (which is one class as created by r.mapcalc).
> This works quite ok, but tends to be slow when there are lots of
> islands (eg buildings) in the inundated area.
> How does r.lake work? I couldn't find anything in the docs.
> Thanks,
> -Jeroen.
Type: application/x-tgz
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060520/a398a00d/r.lake.bin
