[GRASS-user] d.vect not using RGB values in attribute table
    Dylan Beaudette
    dylan.beaudette at gmail.com
    Mon May 22 18:34:53 EDT 2006
On Monday 22 May 2006 11:47, Huidae Cho wrote:
> Dylan,
> Here is a screenshot of "d.vect -a mapname type=area".  I have no idea
> what's going on in your grass.
> http://geni.ath.cx/tmp/screenshot.png
> Does anyone have any idea?
> Huidae Cho
Yikes... I just tried re-importing the shapefile that I sent you, and it
renders correctly.... I wonder if this has something to do with db
connectivity / naming issues...
I tried making a copy of the GRASS vector such that the copy had matching
vector and table names... but colors are still not displayed correctly.
I might have to give up on this for now, but it is very odd that features are
not being colored in the original vector.
I connected up the original table to the vector in question, and added a
GRASSRGB column to it. These colors displayed fine. However connecting a
different table to the same vector results in only a few areas being colored.
Interactively querying the vector with d.what.vect reveals that there are in
fact attributes associated with these areas, including the GRASSRGB values...
Dylan
> On Mon, May 22, 2006 at 11:38:50AM -0700, Dylan Beaudette wrote:
> > On Monday 22 May 2006 10:16, Huidae Cho wrote:
> > > Interesting...  Were these polygons displayed correctly before I added
> > > wcolumn= and wscale=? Or is this the first time you use -a for this
> > > map? try to insert the following line just above "} /* end if
> > > table_colors_flag */" in area.c:
> > > fprintf(stderr, "colorstring:: area=%d cat=%d rgb=%d r=%d g=%d b=%d\n",
> > > area, cat, rgb, red, grn, blu);
> > > and run the same command.  If you don't mind, could you send me
> > > (without CC to the list) a copy of the map?
> > > Huidae Cho
> > Huidae,
> > thanks for the quick reply.
> > This is the first time that I have tried using the -a flag on this map.
> > here is a link to a shapefile of this map:
> > http://169.237.35.250/~dylan/temp/ca_suborder.tar.gz
> > I will try the source code modification a little later today.
> > Cheers,
> > Dylan
> > > On Mon, May 22, 2006 at 10:04:26AM -0700, Dylan Beaudette wrote:
> > > > Ok, a bit more information.
> > > > Rebuilt with today's CVS, and noticed that following:
> > > > d.vect -a ca_statsgo  2>&1 | grep colorstring
> > > > D3/3: area 508: colorstring: 28:58:205
> > > > D3/3: area 2962: colorstring: 28:58:205
> > > > D3/3: element 11933: colorstring: 179:113:29
> > > > D3/3: element 12037: colorstring: 174:0:239
> > > > D3/3: element 12038: colorstring: 174:0:239
> > > > D3/3: element 12393: colorstring: 28:58:205
> > > > D3/3: element 12772: colorstring: 179:113:29
> > > > D3/3: element 12776: colorstring: 179:113:29
> > > > D3/3: element 13616: colorstring: 89:107:16
> > > > D3/3: element 13703: colorstring: 241:44:3
> > > > D3/3: element 13777: colorstring: 179:113:29
> > > > D3/3: element 13860: colorstring: 254:1:1
> > > > D3/3: element 14253: colorstring: 202:158:185
> > > > D3/3: element 14290: colorstring: 110:182:71
> > > > D3/3: element 14369: colorstring: 254:1:1
> > > > D3/3: element 14847: colorstring: 28:58:205
> > > > D3/3: element 15466: colorstring: 254:1:1
> > > > D3/3: element 15508: colorstring: 254:1:1
> > > > D3/3: element 15640: colorstring: 181:166:34
> > > > ... however there are hundreds of polygons in this map, and yet I
> > > > only see about 20 lines matching 'colorstring' .. note that a VERY
> > > > small number of polygons are being filled with a non-grey color- but
> > > > I cannot detect any pattern.
> > > > hereis a sample screen shot showing the results of the previous
> > > > command:
> > > > http://169.237.35.250/~dylan/temp/d.vect_probs.png
> > > > vectors are labeled with their GRASSRGB attribute, note that only one
> > > > of the vectors has a fill color that differs from the default.
> > > > Dylan
> > > > On Monday 22 May 2006 08:15, Huidae Cho wrote:
> > > > > I added wcolumn= and wscale= options last week. Hmm.. -a flag works
> > > > > well for me. Try the following:
> > > > > g.gisenv set=DEBUG=3
> > > > > d.vect mapname -a 2>&1 | grep colorstring
> > > > > Do you see any message?
> > > > > Huidae Cho
> > > > > On Sun, May 21, 2006 at 01:22:18PM -0700, Dylan Beaudette wrote:
> > > > > > last weeks CVS:
> > > > > > using d.vect  with the -a flag is not coloring areas based on
> > > > > > colors stored in the attribute table.
> > > > > > | cat  | muid  | suborder_pct | soil_suborder | rgb     |
> > > > > > | GRASSRGB |
> > > > > > | 2735 | CA007 |           15 | orthents      | 254:1:1 | 254:1:1
> > > > > > tried using both an attribute named GRASSRGB, and specifying the
> > > > > > column with the rgb_column=GRASSRGB flag
> > > > > > anyone else noticing this odd behavior?
> > > > > > Thanks!
> > > > > > Dylan Beaudette
> > > > > > Soils and Biogeochemistry Graduate Group
> > > > > > University of California at Davis
> > > > > > 530.754.7341
> > > > > > _______________________________________________
> > > > > > grassuser mailing list
> > > > > > grassuser at grass.itc.it
> > > > > > http://grass.itc.it/mailman/listinfo/grassuser
> > > > Dylan Beaudette
> > > > 530.754.7341
> > Dylan Beaudette
> > 530.754.7341
Dylan Beaudette
530.754.7341
