[GRASS-user] gdal and gdalconst modules?
Tue May 23 10:40:31 EDT 2006
stefano wrote:
> Hello everybody!
> I have a little problem with the raster elaboration.
> I found a useful module at cpan.perl.org, which is Geo::Raster.
> I saw that the prerequisites are the "libral" library, the
> Statistics::Details module and the gdal and gdalconst modules.
> I installed the library and the Statistic module without problems. Then
> I installed the Geo::GDAL module form cpan and I tried to install
> Geo::Raster.
> The error message that was prompted was:
>  >Following required modules are missing: gdalconst gdal.
> I tried to install gdal modules using apt-get and, after getting another
> error,  from sources available from www.gdal.org/dl.
> Everything worked fine, but, when I tried again to install Geo::Raster,
> the error message was the same.
> What can I do??
> My operative system is Debian 3.1 unstable, and everything, except for
> "libral" and "gdal" was installed with apt-get.
Stefano,
I think the key is to configure GDAL with the --with-perl flag then do the
"make" and "make install".  By default I don't believe the perl components
will be built.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
