[GRASS-user] Question on how to satisfy Gdal dependency: libstdc++.la
Patton, Eric epatton at nrcan.gc.ca
Tue May 23 12:42:50 EDT 2006
I'm trying to do a fresh gdal compile for an eventual grass-cvs install. I
want gdal and grass both installed under /opt. I'm using gdal-1.3.2.
Here's my configure line:
./configure --with-png=internal --with-jpeg=internal --with-gif=internal
--with-libtiff=internal --with-geotiff=internal --with-libz=internal
--without-pg --without-ogdi --with-python --with-threads=yes --with-sqlite
--without-grass --without-libgrass --prefix=/opt --bindir=/opt/bin
--enable-shared
And the output:
GDAL is now configured for i686-pc-linux-gnu
  Installation directory:    /opt
  C compiler:                gcc -O2
  C++ compiler:              g++ -O2
  LIBTOOL support:           yes
  LIBZ support:              internal
  GRASS support:             no
  CFITSIO support:           no
  PCRaster support:          internal
  NETCDF support:            yes
  LIBPNG support:            internal
  LIBTIFF support:           internal
  LIBGEOTIFF support:        internal
  LIBJPEG support:           internal
  LIBGIF support:            internal
  OGDI support:              no
  HDF4 support:              no
  HDF5 support:              no
  KAKADU support:            no
  JASPER support:            no
  ECW support:               no
  MrSID support:             no
  POSTGRESQL support:        no
  MySQL support:             no
  XERCES support:            no
  ODBC support:              yes
  OCI support:               no
  SDE support:               no
  DODS support:              no
  SQLite support:            yes
  DWGdirect support          no
  PANORAMA GIS support:      no
  GEOS support:              yes
  Statically link PROJ.4:    no
  Traditional Python:        no
  NG SWIG Bindings:
  enable OGR building:       yes
Make then runs for about 10 minutes, after which it crashes with the
following error:
<snip>
ranlib .libs/libgdal.a
creating libgdal.la
/bin/sed: can't read /usr/lib/libstdc++.la: No such file or directory
libtool: link: `/usr/lib/libstdc++.la' is not a valid libtool archive
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/opt/gdal-1.3.2'
make: *** [check-lib] Error 2
Can I create some kind of symlink for this? Checking in /usr/lib for what I
have installed for libstdc++, I get the following files:
/usr/lib/libstdc++.so.6.0.5
/usr/lib/gcc/i486-linux-gnu/4.0.2/64/libstdc++.a
/usr/lib/gcc/i486-linux-gnu/4.0.2/64/libsupc++.a
/usr/lib/gcc/i486-linux-gnu/4.0.2/libstdc++.a
/usr/lib/gcc/i486-linux-gnu/4.0.2/libsupc++.a
Thanks for any ideas you could provide,
~ Eric.
