[GRASS-user] Question on how to satisfy Gdal dependency: libstdc++.la
Wed May 24 16:37:50 EDT 2006
Patton, Eric wrote:
> I'm trying to do a fresh gdal compile for an eventual grass-cvs install. I
> want gdal and grass both installed under /opt. I'm using gdal-1.3.2.
> <snip>
> ranlib .libs/libgdal.a
> creating libgdal.la
> /bin/sed: can't read /usr/lib/libstdc++.la: No such file or directory
> libtool: link: `/usr/lib/libstdc++.la' is not a valid libtool archive
> make[1]: *** [libgdal.la] Error 1
> make[1]: Leaving directory `/opt/gdal-1.3.2'
> make: *** [check-lib] Error 2
> Can I create some kind of symlink for this?
A .la file is a text file containing metadata for a library; they are
created by and used by libtool.
In particular, libtool cannot use a static library without the
corresponding .la file, as static libraries don't include dependency
information.
> Checking in /usr/lib for what I
> have installed for libstdc++, I get the following files:
> /usr/lib/libstdc++.so.6.0.5
> /usr/lib/gcc/i486-linux-gnu/4.0.2/64/libstdc++.a
> /usr/lib/gcc/i486-linux-gnu/4.0.2/64/libsupc++.a
> /usr/lib/gcc/i486-linux-gnu/4.0.2/libstdc++.a
> /usr/lib/gcc/i486-linux-gnu/4.0.2/libsupc++.a
> Thanks for any ideas you could provide,
I suggest doing:
	ln -s libstdc++.so.6 /usr/lib/libstdc++.so
then start building GDAL from the beginning (i.e. make distclean,
configure, ...).
Hopefully, that will cause it to pick up the shared C++ library rather
than the static version.
