[GRASS-user] Errors starting gis.m;
latest GRASS 6.1 weekly build from cvs; i.e 05_20 and 05_27!
Lars Forseth
l-forset at online.no
Wed May 31 18:05:27 EDT 2006
Hi!
I'm trying to update to the latest GRASS 6.1 cvs; i.e 05_27. It compiles
without a hitch; no errors. After running make install; and then as my self
running grass61 I get an error. I.e the gismanager starts; gives me the
dialog where you choose location etc; but it then failes with the errors
copied in below.
My system is an AMD 64 bit system running suse 9.3. Up to 04_22 the compiling
of the 6.1 cvs version has gone mostly well. Now the two latest versions has
failed with the errors below.
I have little experience with tcltk; so I ask here; whats the error?
Regards
larsf
Error when running grass61:
"Welcome to GRASS 6.1.cvs (2006)
GRASS homepage: http://grass.itc.it/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface with: gis.m &
When ready to quit enter: exit
GRASS 6.1.cvs (Vestfold):~ > Error in startup script: unmatched open brace in
list
while executing
"llength $entry"
(procedure "_create_entries" line 7)
invoked from within
"_create_entries $path $menu $bg $entries"
(procedure "_create_menubar" line 34)
invoked from within
"_create_menubar $path $menu"
(procedure "MainFrame::create" line 63)
invoked from within
"MainFrame::create .mainframe -menu {&File all file 1 {
{cascad {Workspace} {} "" 1 {
{command {Open...} {} "Open gis.m workspace file" {} -acc..."
("eval" body line 1)
invoked from within
"eval MainFrame::create $path $args"
(procedure "MainFrame" line 1)
invoked from within
"MainFrame .mainframe -menu $descmenu -textvariable Gm::status -progressvar
Gm::prgindic "
(procedure "Gm::create" line 29)
invoked from within
"Gm::create"
(procedure "main" line 29)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.1.cvs/etc/gm/gm.tcl" line 518)"
