[GRASS-user] SQLite - Mac OS X
Dave Kent
dkent at sasktel.net
Wed May 31 20:44:46 EDT 2006
Hi all:
I am trying to move to SQLite database from dbf using latest CVS (Mr.
Moretti binaries, 30 May 06) on Mac 10.4.
I have not installed SQLite but am using the version embedded in
Tiger 10.4 Is this sufficient?
I have successfully imported a small .shp file and viewed it with
SQLite Database Browser.
db.connect works.
db.test returns all OK except for
RESULT: OK
select c1 from grass_test1 where d1 < 500 / 2 and i1 <> 2 and c1 ~
'bc'
-SQLite driver error:
Error in sqlite3_prepare():select c1 from grass_test1 where d1 <
500 / 2 and i1 <> 2 and c1 ~ 'bc'
near "~": syntax error
EXECUTE: ******** ERROR ********
0a1
> abcd
RESULT: ******** ERROR ********
insert into grass_test1 values ( 3, 0.0, '_''_' )
EXECUTE: OK
I have a problem importing a points file with v.in.ascii. The import
works well with dbf driver. When I change to SQLite driver (no other
changes) I get the following error:
Length of column 3 (-1) is less than maximum value length (9)
I have specified column 3 as 'name1 varchar(30)' Is there a
different syntax to specify character string variables in SQLite?
Thanks in advance for your help.
Dave
