[GRASS-user] grass and postresql drivers for remote db
G. Allegri
giohappy at gmail.com
Sun Nov 5 18:42:58 EST 2006
Thanks everyone, I'll have a look to my ubuntu repository packages:
- postgresql-client-8.1
- postgresql-dev (even if this seems to be related to version 7.5.21...)
Giovanni
2006/11/5, Glynn Clements <glynn at gclements.plus.com>:
> G. Allegri wrote:
> > I need to use a remote Postgresql connection with Grass. When compiling
it I
> > have to set the "--with-postgres" option during configuration but is it
> > required to have postgresql installed to enable it? I know that the
postgres
> > libraries are needed, is it enough to download them?
> To compile GRASS with PostgreSQL support, you need to have the
> PostgreSQL libraries and headers installed on the build system. You
> don't need to install the server.
> If your distribution has a package named something like "libpq" or
> "posgresql-client", you need that, and also the corresponding -devel
> package if there is one.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20061106/ad9adc76/attachment.html
