[GRASS-user] GPJ_wkt_to_grass error in making r.in.gdal
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Nov 7 06:31:33 EST 2006
You also need to re-run the GRASS configure script so that it will pick up
that OGR is enabled now, and re-compile the parts of GRASS that will be
affected by the change: it's possible that all you need to do is:
cd lib/proj
make clean
make
and then a top-level make should pick up all the functions v.*.ogr,
r.in.gdal need to run. g.proj should also have improved functionality; you
might try a make clean in general/g.proj too after re-compiling lib/proj.
g.proj fails gracefully (i.e. compiles, but with reduced functionality) if
OGR is disabled, whereas r.*.gdal and v.*.ogr just fail to compile.
Paul
On Tue, 7 Nov 2006, Gerald Nelson wrote:
> I was using this configure command
> ./configure --with-grass=no --with-png=internal --with-jpeg=internal
>            --with-gif=internal --with-libtiff=internal
>            --with-geotiff=internal --with-libz=internal --without-ogr
>            --without-pg --without-ogdi --with-gdal=/usr/local/bin/gdal-config
> I tried it with the "--without-ogr" deleted. This time when I make grass I get errors in r.in.gdal, v.out.ogr, and v.in.ogr.  Should I be using "--with-ogr"?
> ---- Original message ----
>> Date: Tue, 7 Nov 2006 10:48:25 +0000 (GMT)
>> From: Paul Kelly <paul-grass at stjohnspoint.co.uk>
>> Subject: Re: [GRASS-user] GPJ_wkt_to_grass error in making r.in.gdal
>> To: JerryNelson <gnelson at uiuc.edu>
>> Cc: grassuser at grass.itc.it
>> Have you disabled OGR support in GDAL? The GPJ_wkt_to_grass() function
>> will only be compiled into the GRASS gproj library if OGR is available. If
>> you don't have OGR you won't be able to convert co-ordinate system
>> information into the forms used in other GIS. Perhaps the call to
>> GPJ_wkt_to_grass() should be conditionalised on HAVE_OGR, but especially
>> if you're using GDAL it's pretty unlikely to not have OGR compiled into
>> it.
>> On Mon, 6 Nov 2006, JerryNelson wrote:
>>> I'm trying to build grass63 from source. I get most of the way there but then
>>> run into a problem with the grass make. What breaks is in the r.in.gdal
>>> make. I'm told there are undefined references to GPJ_wkt_to_grass. I'm using
>>> CentOS, which is a variant of redhat. I have (I think) successfully
>>> installed GDAL without grass, postgresql, and proj. There was some traffic
>>> in August about someone else having this problem but I can't find where a
>>> solution was found.
>>> Any help appreciated.
>>> Thanks, Jerry
>>> View this message in context: http://www.nabble.com/GPJ_wkt_to_grass-error-in-making-r.in.gdal-tf2586498.html#a7211765
>>> Sent from the Grass - Users mailing list archive at Nabble.com.
>>> grassuser mailing list
>>> http://grass.itc.it/mailman/listinfo/grassuser
> Gerald Nelson
> Professor, Dept. of Agricultural and Consumer Economics
> University of Illinois, Urbana-Champaign
> office: 217-333-6465
> cell: 217-390-7888
> 315 Mumford Hall
> 1301 W. Gregory
> Urbana, IL 61801
