[GRASS-user] GPJ_wkt_to_grass error in
making r.in.gdal
Gerald Nelson
gnelson at uiuc.edu
Tue Nov 7 06:26:26 EST 2006
I was using this configure command
./configure --with-grass=no --with-png=internal --with-jpeg=internal
--with-gif=internal --with-libtiff=internal
--with-geotiff=internal --with-libz=internal --without-ogr
--without-pg --without-ogdi --with-gdal=/usr/local/bin/gdal-config
I tried it with the "--without-ogr" deleted. This time when I make grass I get errors in r.in.gdal, v.out.ogr, and v.in.ogr. Should I be using "--with-ogr"?
---- Original message ----
>Date: Tue, 7 Nov 2006 10:48:25 +0000 (GMT)
>From: Paul Kelly <paul-grass at stjohnspoint.co.uk>
>Subject: Re: [GRASS-user] GPJ_wkt_to_grass error in making r.in.gdal
>To: JerryNelson <gnelson at uiuc.edu>
>Cc: grassuser at grass.itc.it
>Have you disabled OGR support in GDAL? The GPJ_wkt_to_grass() function
>will only be compiled into the GRASS gproj library if OGR is available. If
>you don't have OGR you won't be able to convert co-ordinate system
>information into the forms used in other GIS. Perhaps the call to
>GPJ_wkt_to_grass() should be conditionalised on HAVE_OGR, but especially
>if you're using GDAL it's pretty unlikely to not have OGR compiled into
>it.
>On Mon, 6 Nov 2006, JerryNelson wrote:
>> I'm trying to build grass63 from source. I get most of the way there but then
>> run into a problem with the grass make. What breaks is in the r.in.gdal
>> make. I'm told there are undefined references to GPJ_wkt_to_grass. I'm using
>> CentOS, which is a variant of redhat. I have (I think) successfully
>> installed GDAL without grass, postgresql, and proj. There was some traffic
>> in August about someone else having this problem but I can't find where a
>> solution was found.
>> Any help appreciated.
>> Thanks, Jerry
>> View this message in context: http://www.nabble.com/GPJ_wkt_to_grass-error-in-making-r.in.gdal-tf2586498.html#a7211765
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grassuser mailing list
>> http://grass.itc.it/mailman/listinfo/grassuser
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
