[GRASS-user] GPJ_wkt_to_grass error in making r.in.gdal
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Nov 7 05:48:25 EST 2006
Have you disabled OGR support in GDAL? The GPJ_wkt_to_grass() function
will only be compiled into the GRASS gproj library if OGR is available. If
you don't have OGR you won't be able to convert co-ordinate system
information into the forms used in other GIS. Perhaps the call to
GPJ_wkt_to_grass() should be conditionalised on HAVE_OGR, but especially
if you're using GDAL it's pretty unlikely to not have OGR compiled into
it.
On Mon, 6 Nov 2006, JerryNelson wrote:
> I'm trying to build grass63 from source. I get most of the way there but then
> run into a problem with the grass make. What breaks is in the r.in.gdal
> make. I'm told there are undefined references to GPJ_wkt_to_grass. I'm using
> CentOS, which is a variant of redhat. I have (I think) successfully
> installed GDAL without grass, postgresql, and proj. There was some traffic
> in August about someone else having this problem but I can't find where a
> solution was found.
> Any help appreciated.
> Thanks, Jerry
> View this message in context: http://www.nabble.com/GPJ_wkt_to_grass-error-in-making-r.in.gdal-tf2586498.html#a7211765
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
