[GRASS-user] d.histogram in grass6.2
Markus Neteler
neteler at itc.it
Wed Nov 8 12:20:38 EST 2006
Javier,
I have triggered the GRASS 6.2.relbranch snapshot:
http://grass.itc.it/grass62/source/snapshot/
This will become 6.2.1, so testing is welcome.
Fixed done there are listed here:
http://grass.gdf-hannover.de/wiki/GRASS_6.2_Feature_Plan#6.2.1
Markus
On Wed, Nov 08, 2006 at 05:24:25PM +0100, Javier Álvarez Rodríguez wrote:
> Thanks a lot for your help Michael and Hamish. I think that the point I
> wasn't able to explain better was the one Hamish fixed. What we want is to
> draw statistics, a raster map and the histogram in only one window. We use
> d.frame and d.mon in command mode to divide the monitor and display all
> these layers in the same monitor. And if I have understood well from
> Hamish answer, there is nothing to do because d.histogram have been
> compiled to remove frames from the active monitor and we should wait for
> other versions. Am I right?
> Best regards
> Javier Alvarez Rodriguez
> Area de Hidrologia del Centro de Estudios Hidrograficos del CEDEX
> Paseo Bajo de la Virgen del Puerto, 3
> Madrid 28007. Espana
> +34 91 335 79 38
> +34 91 335 79 22
> javier.alvarez at cedex.es
> De: Michael Barton [mailto:michael.barton at asu.edu]
> Enviado el: miercoles, 08 de noviembre de 2006 15:41
> Para: Javier A lvarez Rodr i guez; grassuser at grass.itc.it
> Asunto: Re: [GRASS-user] d.histogram in grass6.2
> It is sounding like there are 2 different issues.
> One was a bug in recent updates to d.histogram that Hamish just fixed.
> The second is d.frame. D.frame doesn't work correctly with TclTk canvases;
> it is really designed to work with an xmonitor display. The d.frame module
> still exists, but you will need to run it from the command line with an
> xmonitor (called with d.mon). Note that xmonitors are only available in
> x11 versions of GRASS (not windows native or Mac aqua).
> On the other hand, the new GUI structure allows you to have a histogram
> displayed in one window, raster map in another, statistics in yet another,
> etc. Each window now has its own independent layer tree and zoom settings,
> that are preserved regardless of what you do with other windows. So you
> can get much the same results--though not in a single display window.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: [1]http://www.public.asu.edu/~cmbarton
> From: Javier Alvarez Rodriguez <javier.alvarez at cedex.es>
> Date: Wed, 8 Nov 2006 08:13:26 +0100
> To: <grassuser at grass.itc.it>
> Subject: RE: [GRASS-user] d.histogram in grass6.2
> Sorry about it. I'll try again. When using the new d.histogram version
> (grass6.2), we found that the histogram is displayed after deleting the
> whole active monitor. Previous version allows composing in the active
> monitor several frames to display on them whatever the user wants. New
> version doesn't let us to divide the monitor (or don't know how to do
> that) in several frames to display at the same time other information
> apart from the histogram, for example, the raster map, statistics and so
> on. I'm afraid I haven't clarified it at all ...
> Best regards
> +34 91 335 79 38
> +34 91 335 79 22
> De: Michael Barton [[2]mailto:michael.barton at asu.edu]
> Enviado el: martes, 07 de noviembre de 2006 23:47
> Para: Javier A lvarez Rodr i guez; GRASS
> Javier,
> Could you explain better what you would like to do? I think what you want
> is quite possible, but I don't quite understand you.
> Michael
> Center for Social Dynamics and Complexity
> phone: 480-965-6213
> fax: 480-965-7671
> www: [3]http://www.public.asu.edu/~cmbarton
> Date: Tue, 7 Nov 2006 12:26:59 +0100
> To: GRASS <grassuser at grass.itc.it>
> Subject: [GRASS-user] d.histogram in grass6.2
> Dear all,
> We've implemented new grass6.2 stable version and found a difference in
> d.histogram use. Is there any possibility of not deleting the whole active
> monitor and display the histogram in a chosen frame in the active monitor?
> Thanks in advance
> +34 91 335 79 38
> +34 91 335 79 22
> References
> Visible links
> 1. http://www.public.asu.edu/~cmbarton
> 2. mailto:michael.barton at asu.edu%5d
> 3. http://www.public.asu.edu/~cmbarton
