[GRASS-user] How to JOIN a table to vector layer using MySQL
    Jarek Jasiewicz
    jarekj at amu.edu.pl
    Wed Nov  8 15:33:08 EST 2006
Nicolas Devaux napisał(a):
> Hi, I'm using Grass 6.0 (I will use 6.2 soon, but I need to go further
> with 6.0 version until one month).
> I would like to join a vector table with external attribute table
> using MySQL.
> I created the MySQL Database, and did the v.dbconnect with MySQL drivers.
> I did the Join operation with Mysql and it works perfectly. But, when
> I come back in Grass, it is not possible to see the result within the
> attribute table... Joined attributes are not in the table. It seems
> that grass is not able to see results of the joined operation made in
> Mysql.
> Does some body has any suggestion ?
> To resume my problem, I can say that I just try to do a join operation
> on vector attribute table, and that this operation seems to be a
> little bit difficult with Grass.
> Thanks
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
well grass not see joined tables. the only way as I thing is to use SQL
command CREATE TABLE nova AS
SELECT a.cat ..... FROM a INNER JOIN b ON .......;
nad reconnect vector to nova table (a.cat MUST be in SELECT section)
I use it very ofen but... on PgSQL. I'm not sure if CRATE TABLE AS works
on mysql
regards
Jarek
