[GRASS-user] How to JOIN a table to vector layer using MySQL
Raffaele Morelli
raffaele.morelli at gmail.com
Fri Nov 10 10:05:46 EST 2006
2006/11/9, Moritz Lennert <mlennert at club.worldonline.be>:
> > (...!!!...) ok, this works. But now I have some questions about it.
> > "v.db.connect -o map=MyMap table=TABLE key=KeyCol driver=mysql
> > database=grass layer=2"
> > this connects my map with a static table on layer 1
> No, layer 2.
Right, a typing error
> Probably you do not have any objects defined in layer 2.
> see this thread to see if you don't have the same problem:
> http://grass.itc.it/pipermail/grass5/2005-September/019592.html
Yes, exactly this
If you want an object in your map to have layer 2 defined, you can
> either do this by hand in v.digit, or automatically with v.category:
> v.category in=MyMap out=MyMap2 option=add layer=2
> Moritz
Ok, finally you can add my name to the list of users who didn't understand
how layers work ;)
This will save a lot of time
Thank you
Raffaele
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20061110/27a5f6f9/attachment.html
