[GRASS-user] nulls left by r.surf.nnbathy
    Nick Cahill
    ndcahill at wisc.edu
    Thu Nov  9 08:38:19 EST 2006
I'm trying to create a dem from digitized contour lines with
r.surf.nnbathy. I've started with vector contour lines, converted
them to a raster with v.to.rast, then interpolate these using
r.surf.nnbathy. The output looks good, except that it is speckled
with random-looking null cells, as in the enclosed screen shot (white
are nulls)
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20061109/7045eb44/DEMwithNulls.jpg
I can't figure out what is causing these: some are on a contour line,
some are between contours; I don't see an obvious pattern. Is this a
known issue with r.surf.nnbathy, and if so, is there a workaround?
On a related note, when I've tried to fill the nulls with
r.fillnulls, the program crashes gis.m with a segmentation fault,
leaving a couple temporary rasters and a mask.
I'm running GRASS 6.3, on Mac OS X 10.4.8, using William
Kyngesburye's excellent binaries (dated 9/29/06, maybe not the most
recent build). I built the binary for nnbathy myself; perhaps this is
the problem. How would I test that?
Many thanks for any help anyone could offer --
best to all,
Nick Cahill
University of Wisconsin-Madison
