[GRASS-user] d.histogram in grass6.2
Javier Álvarez Rodríguez
javier.alvarez at cedex.es
Fri Nov 10 01:44:11 EST 2006
Thanks Hamish,
We use similar scripts to divide the monitor in different frames. And this
is what doesn't work with new d.histogram. If I've understood, the reason is
what you stated in your previous email. Is there any possibility of using a
modified d.histogram command, without this monitor-removing-everything
option, in grass6.2 version?
Best regards
Área de Hidrología del Centro de Estudios Hidrográficos del CEDEX
Paseo Bajo de la Virgen del Puerto, 3
Madrid 28007. España
+34 91 335 79 38
+34 91 335 79 22
-----Mensaje original-----
De: Hamish [mailto:hamish_nospam at yahoo.com]
Enviado el: jueves, 09 de noviembre de 2006 3:31
Para: Javier Álvarez Rodríguez
CC: grassuser at grass.itc.it
Asunto: Re: [GRASS-user] d.histogram in grass6.2
Javier Álvarez Rodríguez wrote:
> Thanks a lot for your help Michael and Hamish. I think that the point
> I wasn't able to explain better was the one Hamish fixed. What we want
> is to draw statistics, a raster map and the histogram in only one
> window. We use d.frame and d.mon in command mode to divide the monitor
> and display all these layers in the same monitor.
others have answered all questions I think, so a tip:
check out the "d.frame.quarter" script from the Add-ons section of the
GRASS Wiki site. It quickly splits the xmonitor up into 4 named
quadrants.
http://grass.gdf-hannover.de/wiki/GRASS_AddOns#Display_add-ons
Hamish
