[GRASS-user] nulls left by r.surf.nnbathy
Maciej Sieczka
tutey at o2.pl
Mon Nov 13 17:14:16 EST 2006
Robert Nuske wrote:
>> Nick Cahill wrote:
>>> I'm trying to create a dem from digitized contour lines with
>>> r.surf.nnbathy.
>>> The output looks good, except that it is speckled with random-looking
>>> null cells, as in the enclosed screen shot (white are nulls)
> I had the same problem as Nick and couldn't figure what is causing these
> speckles. While collecting cases for a report i decided not to interpolate the
> data at all.
Robert and Nick,
Are you both using Mac?
Please reproduce the error with small datasets, and send them over to
me along with your exact region settings, r.surf.nnbathy syntax and the
nnbathy version you used (if you built it yourself, specify if "serial
processing" enabled).
Like I said, r.surf.nnbathy has been working well for me. If you want
me to help you I need details.
Cheers,
Maciek
