[GRASS-user] Wave models
Hamish
hamish_nospam at yahoo.com
Thu Nov 16 01:49:21 EST 2006
Armando Scalise wrote:
> I am starting a project to model ocean waves refraction using GRASS,
> by applying the Runge-Kutta method for solving differential equations.
> I have made a search on the internet, and found scarce references to
> existing works.
> I would appreciate any leads to examples and previous works.
A couple of us have used the SWAN wave model (GPL, FORTRAN) with GRASS.
http://fluidmechanics.tudelft.nl/swan/default.htm
workflow was like:
generate DEM bathymetry in GRASS (v.surf.* and friends)
export bathymetry as ascii grid (r.out.ascii)
set up and run the model
load results into Matlab
do_stuff()
import back into GRASS with r.in.mat
do_stuff()
plot it. (ps.map, d.rast.arrow, r.contour, thresholds, ...)
Hamish
