[GRASS-user] Re: [GRASS-dev] 3D DXF output: howto?
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Thu Nov 16 08:55:57 EST 2006
Thanks, that's a very interesting hint.
Benjamin
Markus Neteler wrote:
> Ah, now I got it... So, alternatively you can do:
> with
> v.to.db option=coor ...
> you could upload the x and y values to the attribute table,
> then re-create a map with
> v.in.db ...
> Markus
> Benjamin Ducke wrote on 11/16/2006 11:48 AM:
>>OK, v.drape worked for me, though I find it a little annoying
>>that I have to first convert the elevation attribute to a
>>raster, than use that to grab 3D coordinates off it.
>>I was hoping there might be a more elegant way to just copy
>>the elevation attribute into the Z coordinate and create
>>and thus convert a 3D points map to 3D directly.
>>I can confirm that 3D dxf export works fine, at least for points.
>>Thanks a lot for the hint,
>>Benjamin
>>>Hi Benjamin,
>>>(I have taken out grass-dev to avoid too much cross-posting)
>>>Benjamin Ducke wrote on 11/16/2006 09:37 AM:
>>>>Hi everyone,
>>>>I am currently trying to get some 3D points out of GRASS and into a
>>>>3D modeller (blender.org) fur further processing.
>>>>Two questions arise:
>>>>1. My GRASS vector points are 2D + elevation attribute. Is it possible
>>>>to map the elevation attribute to a Z coordinate and create a 3D map?
>>>v.drape will do that for you.
>>>>2. Is it possible to output 3D vector points as 3D DXF?
>>>v.out.dxf seems to set 3D dxf vertices. Doesn't it work?
>>>Markus
>>>_______________________________________________
>>>grassuser mailing list
>>>grassuser at grass.itc.it
>>>http://grass.itc.it/mailman/listinfo/grassuser
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
