[GRASS-user] mysterious error (WARNING: Cannot open old vector
on level 2)
Hamish
hamish_nospam at yahoo.com
Wed Nov 22 20:53:50 EST 2006
Henry House wrote:
> I'm having mysterious errors trying to use various modules in my
> database (GRASS 6.1 running on Debian), which contains mapsets
> PERMANENT and hajhouse.
> example:
> GRASS 6.1.cvs (sacramento_sanjoaquin):~/grass > ps.map
> in=Scripts/psmap_script output=out.ps
> WARNING: Cannot open old vector soil at hajhouse on level 2
> ERROR: soil in hajhouse : can't open vector file
> g.list vect reports:
> vector files available in mapset hajhouse:
> soil
> vector files available in mapset PERMANENT:
> cont_10 cty_bounds hydro plsa rd_local
> rd_state
> rd_usa soilmu_a_sac soilmu_l_sac soilmu_p_sac soilsa_a_sac
> soilsf_l_sac
> soilsf_p_sac urban
> Trying to use v.out.ogr fails with the same error. Trying to display a
> layer in QGIS (via grass plugin) fails with a rather unhelpful error
> that the layer is not a valid layer. The error presented is the same
> for soilmu_a_sac at PERMANENT and soil at hajhouse but some other layers in
> this database work fine with all GRASS modules. All the layers
> including the problematic ones display fine in the GRASS GIS manager,
> however.
> What is puzzling and frustrating about this is that it worked fine a
> month or so ago. Then I set work in GRASS aside for a month and now
> that I have resumed the errors are here. I have not altered my GRASS
> binaries or support files in the meanwhile, and AFAIK my OS library
> versions have not been updated either.
rebuilt topology with:
v.build soils
or
v.build.all # to rebuild all vector maps in current mapset
then it should work again.
(unless files are totally corrupt on the disk)
Hamish
