[GRASS-user] mysterious error (WARNING: Cannot open old vector
	on level 2)
    Maciej Sieczka
    tutey at o2.pl
    Thu Nov 23 14:25:44 EST 2006
Jarosław Jasiewicz wrote:
> Dylan Beaudette napisał(a):
>> I have encountered this type of error when digitizing GRASS vectors in
>> QGIS- and something bizzare happens. Normally re-building the topology
>> with v.build solved the problem.
> 1. this error also heppens when you create file and leave it empty - it
> is normal - no topology can be build
> 2. I also had a problem with vectors after editing with qgis (file
> totally corupted v.build not helped). So I resign to use qgis as a
> editor for grass vector. I see, more people has the same problem
Well, I for one never had such a problem as Jarek and Dylan describe -
QGIS never corrupted any GRASS vector for me. Even if QGIS crashes
during digitizing, v.build always helps, and QGIS doesn't crash that
easily these days; v.digit freezes or crashes for me more often AAMOF.
Honestly, QGIS 0.8 provides a really good vector digitizing tool for
GRASS. Using it is more convenient and time efficient than using
v.digit, and it doesn't suffer it's numerous problems (has it's own
problems though, yet less harmfull that those in v.digit; and they are
being fixed).
If you found bugs in QGIS GRASS digitizer please report them. There is
a major bug squashing ongoing in QGIS currently, your input could help!
Cheers,
Maciek
